I have gone through the “LIN slave implementation” documentation and referring the reference code available at link[1]. The reference code was compiled successfully
In a similar way, I am trying to implement the code on another target CY8C4147AZA-S455 but unable to get any LIN frames on the pin
I am not sure if anything is missing
Things I have tried:
- Replicate init and send frame sequence from LIN component reference code but no data on DSO
- Explicitly set NSLP pin to high (active low) to avoid sleep behavior o transceiver IC
Test setup:
LIN line (after transceiver IC) connected to DSO to see sent frame. Periodically also monitoring LIN1_TX pin (before transceiver IC) directly from MCU
Attaching reference project and my project
Kindly help on this at earliest,
Eshwar
Hi Eshwar,
LIN communication needs LIN Master for communication to happen. I understand there is no master in your setup (correct me if I am wrong). Following is the flow:
1) The master generates header which contains break field, sync and PID field. Slaves can not generate header, so they can't initiate communication.
2) Based on the header and PID (protected identifier field), the slave will respond accordingly.
Since in your case, there is no master, so header is not generated, so communication is not even initiated. So you can not see any activity on the BUS.
Ashish
I have a question: Do you have LIN Master? It could be either LIN Analyzer working as Master, or any other LIN Master device. The Master should generate the PID in order for LIN Slave (our PSoC in this case) to respond. Unfortunately, PSoC4 device does not have LIN Master component, so as of now, we can only support the LIN Slave using PSoC4, so you will need the Analyzer or any other device working as LIN Master. Also, I don't think the DSO will work as LIN Master, although you can observe the frame on it by connecting it to a working LIN bus.
For getting started, we also request you to refer these KBAs:
1)Getting Started with PSoC® 4 LIN Slave Componen... | Cypress Developer Community
2)Local Interconnect Network (LIN) Slave Componen... | Cypress Developer Community
Ashish
AshishS_66 Hello Ashish,
Thanks for your reply. I have already referred the links suggested by you. I am not trying to use DSO as LIN master, I am trying to observe only the LIN frame on DSO without master. Below is the code snippet from main(). PFA an illustration of the setup. The following code snippet must give output to LIN_TX pin (on test pads) which I want to see on DSO. I am not able to get any output on LIN_TX pin (before transceiver IC). If you could please check on the project add your suggestions/comments related to code or block configuration
Eshwar
/* Enable Global Interrupts */
CyGlobalIntEnable;
/* Call initialization function */
l_sys_init();
/* Start LINS component */
if(0u != l_ifc_init(LINS_IFC_HANDLE))
/* Turn ON the LED1 */
LED1_ON;
// Set to disable sleep (active LOW)
LIN_NSLP_Write(1);
// Send test data forever
while(1)
uint8 testData = 0x05;
l_u8_wr(OutSig_SIGNAL_HANDLE, testData);
l_u8_wr_OutArraySig(testData);
CyDelay(2000);
Hi Eshwar,
Ashish
