D_Sd_3235936
Level 4
Level 4
25 sign-ins 50 questions asked 25 replies posted
I was asked to display cpu pins drive mode for all the CPU pins.
Found only the " SetDriveMode(uint8 mode)"
Is there a GetDriveMode() function available as well?
if not, how can i do it?
Ekta
750 replies posted First like given 250 solutions authored
You can read the PRT_PC register corresponding to the particular port using the CY_GET_REG32(). The GPIO drive mode is stored in the  [23:0] of the 32 bit register. Three bits are used for each pin. Please have a look at the Registers TRM for more details.
Ekta
Ekta
Ekta
