LUBA_1714456
First solution authored 10 replies posted 5 replies posted
Hi Ganesh, may be my reply of last week had some mistakes.... I see "....the discussion is blocked"
In effect I made some errors attaching my project, sorry.
Can we resume from your kind request to send you my project?
Here it is.
Pls notice that I have done many attempts to exit from DEEP SLEEP, having a look from the web, but still I'm stuck!
CPU enters DEEP SLEEP, exits for Advertising, but completely ignores my GPIO transitions!
Please help me.... this job is taking too much time and I am late....
Thanks in advance
Luigi
VenkataD_41
I have gone through the project and reproduced the problem you are facing at my side.
The issue got resolved when I added the lines before and after calling the CySysPmDeepSleep( ) API.
                    Pin_1_SetInterruptMode(Pin_1_0_INTR, Pin_1_INTR_FALLING);
                    CySysPmDeepSleep();
                    Pin_1_SetInterruptMode(Pin_1_0_INTR, Pin_1_INTR_NONE);
I made the above changes because in your code the line  Pin_1_SetInterruptMode(Pin_1_0_INTR, Pin_1_INTR_NONE); is present after the CySysPmSleep(); API and because of that the Pin interrupt is disabled. Even I if disable Pin_1_SetInterruptMode(Pin_1_0_INTR, Pin_1_INTR_NONE); your project is working fine.
We recommend you to keep the Pin_1 Drive mode as Resistive pull-up instead of High impedance digital. Please try this and update if it is working same for you.
Ganesh
VenkataD_41
                    CySysPmDeepSleep();
Ganesh
Non way to answer on web page…
Thanks a lot
BR
Luigi
<http://www.shd-elettronica.it/> <https://www.facebook.com/SHDCuneo/> <https://www.instagram.com/s.h.d._elettronica/>
Bassignana Luigi.
S.H.D. s.a.s.
<http://www.shd-elettronica.it/> Sito : www.shd-elettronica.it
Email <mailto:luigi.bassignana@shd-elettronica.it> luigi.bassignana@shd-elettronica.it
Tel - Fax : +39 0171 348019
