PSoC™ 4 Forum Discussions
D_Sd_3235936
Level 4
Level 4
25 sign-ins 50 questions asked 25 replies posted
The first CC interrupt either lags or happens before time. I always get a value PWM_ReadCounter of below 50. (as described in the picture below)
The issue is only happening on the first activation of PWM and PWM_Isr, following boot.
Next activations looks to work fine.
Code:
StartEx(isr_name) on startup.
Then I activate PWM, WriteCounter(1),  PWM_ISr
MotooTanaka
Level 9
Level 9
I tried with CY8CKIT-043 with the following test project,
but I could not reproduce the problem.
Could you test your board with this project?
schematic
PWM config
pins
main.c
#include "project.h"
#include "stdio.h"
#define STR_LEN 64
char str[STR_LEN+1] ;
void print(char *str)
    UART_UartPutString(str) ;
void cls(void)
    print("\033c") ; /* reset */
    CyDelay(20) ;
    print("\033[2J") ; /* clear screen */
    CyDelay(20) ;
void splash(void)
//    cls() ;
    print("PSoC 4 PWM Interrupt Test") ;
    snprintf(str, STR_LEN, "(%s %s)\n", __DATE__, __TIME__) ;
    print(str) ;
#define NUM_COUNT 10
volatile uint16_t count_buf[NUM_COUNT] ;
volatile int16_t count_index = 0 ;
volatile int     count_flag = 0 ;
CY_ISR(isr_name)
    PWM_BUZZ_ClearInterrupt(PWM_BUZZ_INTR_MASK_CC_MATCH) ;
    count_buf[count_index++] = PWM_BUZZ_ReadCounter() ;
    if (count_index >= NUM_COUNT) {
        count_flag = 1 ;
        isr_1_Disable() ;
void init_hardware(void)
    CyGlobalIntEnable; /* Enable global interrupts. */
    UART_Start() ;
    splash() ;
    isr_1_StartEx(isr_name) ;
    PWM_BUZZ_WriteCounter(1) ;
    PWM_BUZZ_Start() ;
    int i ;
    init_hardware() ;
    for(;;)
        if (count_flag) {
            for(i = 0 ; i < NUM_COUNT ; i++ ) {
                snprintf(str, STR_LEN, "%hu ", count_buf) ;
                print(str) ;
            print("\n\r") ;
            count_flag = 0 ;
/* [] END OF FILE */
Tera Term log
I pushed "reset" many times.
It seems that always the odd ones are bigger than 50 and even ones are less then 50.
moto
MotooTanaka
Level 9
Level 9
schematic
PWM config
pins
main.c
#include "stdio.h"
#define STR_LEN 64
void cls(void)
    CyDelay(20) ;
    CyDelay(20) ;
void splash(void)
//    cls() ;
    print(str) ;
CY_ISR(isr_name)
        count_flag = 1 ;
        isr_1_Disable() ;
    UART_Start() ;
    splash() ;
    PWM_BUZZ_Start() ;
    int i ;
    init_hardware() ;
    for(;;)
        if (count_flag) {
                print(str) ;
            print("\n\r") ;
            count_flag = 0 ;
Tera Term log
moto
