using the following configuration:
Environment:
PSoC Creator  4.2 (4.2.0.641)
OS Version: Microsoft Windows NT 10.0.16299.0
CLR Version: 4.0.30319.42000
When I am tiying to compile the project, by using the EZI2C in order to get the tune helper for a CSD component, i get the following failure:
fit.M0059: FFB and IO placement failed: Failed to fing a valid placement for \SCB:SCB\.
When i am trying to compile with another computer, the failure does not appears.
I do not find the différences between the 2 computers.
Has anyone any idea how to proceed?
Thans.
Thomas FERRY.
BragadeeshV
Can you recheck if you have connected the SCB component to the right pins? Tell me the device you are using and the pins you have connected the SCB block to?
Bragadeesh
Bragadeesh
I have just tryed today and it has compiled without doing any changes.
I do not understand why yesterday it was not the case.
Thanks anyway for your answer.
Regards.
