I am learning CAPSENSE slide on the CY8CKIT-149. the routine and my owm project work normally in PSoC Creator IDE. In modustoolbox2.4 IDE, The CAPSENSE_CSD_Slider_Tuning routine work normally。 I created a project according to this routine. In the Capsense tuner, I checked, but there was no response. After debugging, I found that the function Cy_ CapSense_ Enable return value is CY_CAPSENSE_STATUS_INVALID_STATE. Why CAPSENSE fails to enable?
I am attaching project .Thank..
ispn:40045:1:0
l1:314:1:0
Interrupt will be served in CapSense initialization, in your code __enable_irq() is place much to behind, cause capsense isr cannot be served normally in CapSense initialization process.
You should put __enable_irq() just before EZI2C and CapSense init code.
cy_rslt_t result;
cy_status status = CYRET_SUCCESS;
/* Initialize the device and board peripherals */
result = cybsp_init() ;
if (result != CY_RSLT_SUCCESS)
CY_ASSERT(0);
__enable_irq();
/* EZI2C interrupt configuration */
const cy_stc_sysint_t ezi2c_intr_config =
.intrsrc=EZI2C_IRQ,
.intrPriority = EZI2C_INTR_PRIORITY,
Please open the CY8CKIT-149 capsense tuning demo project in Modus Toolbox. I have run it in cy8ckit-149, it works well.
Yes, I know the CY8CKIT-149 capsense tuning demo project is OK. I mean, I build my own project according to the demo does not work properly.
Please compare which is different.
thanks, The code is basically copied from the demo。
compare the capsense configuration. I think you can use compare tool.
OK, l compare the capsense configuration again。Can you tell me what made capsense failed to enable?
Can you tell me what needs to be configured to create a capsense project on the demo board?
I think it is not a configuration problem, because no matter what configuration parameters, it is impossible to affect the enabling of capsense. I now change the configuration to the same as the demo, and the code is the same. However, the capsense enable fails
cy_rslt_t result;
CY_ASSERT(0);
__enable_irq();
.intrsrc=EZI2C_IRQ,
thanks!
thank you very much!
