Ajay1995
5 replies posted First like received 5 questions asked
Hello....
I am Using CY8C4245AXI-483 as a Master For I2C & SPI Communication I get below error during compilation,
FFB and IO placement failed: Failed to find a valid placement for \SPIM:SCB\.
When I Configure I2C & SPI separately there is no error but when I configure I2C & SPI at a time I get above error.
Please check attached  configuration image for your reference.
Thanks  & Regards
AJ
NXTY_Tatebayasi
Distributor - NEXTY (Japan)
50 questions asked 25 likes received 250 sign-ins
Hi, @Ajay1995
If you are allowed to replace the terminals on your board, please uncheck the Lock checkbox on the attached screen and compile the board.
This will automatically result in the correct pin assignments and eliminate the error.
I think from the datasheet that the original error was caused because you were trying to set spi and I2C in the scb1 block.
Chihiro Tatebayashi / NEXTY
NXTY_Tatebayasi
HI, @Ajay1995
I am afraid that unchecking the "Show SPI terminal" checkbox and compiling the device may solve the problem.
For PSoC4200 series, it should be possible to connect them at an internal node without having to place SPI pins.
In my case, I was able to compile without error as shown in the figure below.
I hope this helps you.
Ajay1995
Hello  Chihiro Tatebayashi ...
Your attached configuration is right.
I don't get any error pin no 20 & 21 (Data & Clock Pin) but when I configure SPI (Pin N0-28,29,30,31) & I2C (Pin N0-11,12) I get this error FFB and IO placement failed: Failed to find a valid placement for \SPIM:SCB\.
Please check attached configuration Images & my project for your reference.
Please let me know can I use Pin no 11 &12 for I2C & SPI (Pin N0-28,29,30,31) at same time because I designed my hardware on the same pin.
   AJ
NXTY_Tatebayasi
Hi, @Ajay1995
Ajay1995
I get this error because am using same SCB block for SPI & I2C.
Thank you Chihiro Tatebayashi for your reply...
Thanks & Regards
AJ
