Dear Community Team,
Please find attached project with SCB block for external EEPROM use internal slave I2C block.
The issue we are facing is that when we build this file with SCB block component version 1.2 project gets built correctly. But when we update that component to version 4.0 (latest) . The same program shows 13 critical error and does not get built.
Please suggest us necessary corrections/changes so that we can use latest version 4.0 of SCB block.
Pavan.
PSoC 4 Architecture
Latest changes for I2C component was to introduce a "timeout" parameter. Since this was not present in former versions you will get errors on most APIs. Check the new I2C Datasheet.
Bob
Bob
