HaLi_1053816
First like given Welcome!
I try export psoc creator (psoc 4100ps)programme to keil. However, there was an L6236E error. How should I fix this problem?
Roy_Liu
5 comments on KBA First comment on KBA 10 questions asked
Have a look at this article - Troubleshooting PSoC® Creator™ Issues - KBA217546
It is a long article, you may search with keyword of "L6236E" on that article webpage.
Roy Liu
Roy_Liu
Roy Liu
Thank you for your suggestion, I have fixed this issue. Change the start file, it run well. Thank you again.Build_Error_1_27.png
Roy_Liu
Thanks for sharing the exact resolution.
Roy Liu
