In the CY8CKIT-0420-BLE -A PIONEER KIT, the evaluation board is using to connect the BLE board to the computer.
Is there a diagram that shows which pins in the BLE chip correspond to which pins on the evaluation board?
For example (image attached), after programming the chip how can I move the thermistor pins from the eval board to the BLE board? and what changes in the code?
PSoC general
- pins
Answer,
Oops. A broke the link.
This should work: cy8ckit-042-ble-bluetooth-low-energy-42-compliant-pioneer-kit
Answer,
I have a simple "Answer".
Check out this link: cy8ckit-042-ble-bluetooth-low-energy-42-compliant-pioneer-kit
Near the bottom you will find support documentation which also includes schematic for the evaluation board and a schematic for the BLE module.
Answer,
