I am trying to build the project in which i had used UART[v2.50] with interrupt...But building of the project stops on tech mapping everytime..Any Suggestion??
- motoo tanaka
It would be nice if you can attach your project or similar sample with which we can reproduce the problem.
Meantime, if you show the screen shot or exact message of the compiler it would be a help, too.
Having said that if you create a project with UART with interrupt only,
can you build that project?
If you can, then problem is somewhere else in your original project,
if you can not, you may have problem with your environment.
Since building is stop at tech mapping, may be your project is exceeding the resource of your target device.
moto
moto
Dear hkdholakiya912_4037761-san,
Thank you very much for your attaching the project.
But when I downloaded the file and expanded it,
to my surprise it contained only the project file, "Timed Interrupts.cyprj".
To reproduce the problem, we need the whole set of project,
So would you
(1) Select "Timed Interrupts" in the Workspace Explorer
(2) From menu Build > Clean "Timed Interrupts"
(3) From menu Project > Archive Workspace/Project...
(4) In the Workspace/Project Archiver dialog
select "Minmal"
push [Archive] button
(5) Attach the result zip file to this discussion thread.
Needless to say, if your problem has been solved already, you don't have to do this.
15-Feb-2019
Motoo Tanaka
