Erase SFlash for PSoC4
Lin_Qiang
Level 4
Level 4
5 likes given First like given 50 replies posted
The chip I am using is CY8C4146LQS-S423.
Is there any tool to erase SFlash of this chip? How to use it?
Lin_Qiang
Level 4
Level 4
Hi Rakshith,
Thank you very much for your support.
I modified and recompiled using "Visual Studio 2022" and was able to clear SFlash successfully.
But after the SFlash is cleared successfully, it seems that the PSoC4 chip program must be rewritten to run normally.
The compiled SFlash tool, I added the attachment, it is suitable for Miniprog4.
BestRegards
Rakshith
250 likes received 1000 replies posted 750 replies posted
Hi @Lin_Qiang
Can you please let me know if this thread helps - PSoC 4 Clear SFlash Program
Thanks and Regards,
Rakshith M B
Lin_Qiang
Level 4
Level 4
Hi Rakshith,
thank you for your reply.
But must MiniProg3 be used? My conditions only allow me to use MiniProg4.
BestRegards
Rakshith
Hi @Lin_Qiang
In that case, you will have to modify the source slightly and create your tool. Can you please try modifying the ConnectToMiniProg3() function in the Form1.cs file and let me know if that works? PPCOM does support MiniProg4 as well. So you should be able to add MiniProg4.
Thanks and Regards,
Rakshith M B
Hi Rakshith,
Okay, I try to modify it, can tell me what environment this tool is compiled in.
BestRegards
Hi Rakshith,
Although I modified it, I didn't quite understand how to compile it. Can a modified tool be provided?
In addition, is the default value of SFlash storage 0x00?
BestRegards
Lin_Qiang
Level 4
Level 4
Hi Rakshith,
BestRegards
