Equip yourself to optimize PSoc4 MCUs for Evs at the EV Webinar. Click here to register.
PSoC™ 4 Forum Discussions
umg_4380326
First like received
The enabling of extended range feature for CYBLE-224110-00, tells about defining this register mentioned below
  • What is the use of this registers?What does it do?
  • What is the value and to where is it being  written to ?
  • Is the value changed continuously?
  • How does it impact the sleep state of the module?
  • Will it let the device go into the sleep state?
VenkataD_41
The register is used to Configure the Link Layer to automatically switch PA control pin P3[2] and LNA control pin P3[3].
The value will not be changed. It doesn't impact the sleep state of module and also it doesn't effect the transition between the sleep states.
Ganesh
VenkataD_41
Ganesh
