YoIs_1298666
250 sign-ins 100 replies posted 100 sign-ins
I am using an ECO-based PLL0 clock as HFCLK, but when I execute Em_EEPROM_1_Write (), it automatically switches the clock to IMO.
When I execute Em_EEPROM_1_Write (), it switches from PLL0 to IMO. Can EZI2C and Timer continue to operate without executing EZI2C_Stop () and Timer_Stop ()?
Yocchi
Alakananda_BG
50 likes received 250 sign-ins 250 replies posted
Can you please refer to the PSoC 4 System Reference Guide Flash Section which I have attached below.
https://www.cypress.com/file/220431/download
>>You should stop the EZI2C and Timer before calling the Em_EEPROM_1_Write () API because there may be some glitches during the communication.
>>If it is not possible to stop, then you should make sure the IMO and ECO are same.
Alakananda
Alakananda
Alakananda_BG
Alakananda
Alakananda
Hello Alakananda-san,
Thank you very much for your help.
What does the following mean?
Does it mean setting HFCLK to IMO without using ECO?
Yocchi
Alakananda_BG
>>Yes. You have to use IMO to route to HFCLK
Alakananda
Alakananda
Thank you very much.
Yocchi
