PSoC™ 4 Forum Discussions
adamelli2
First reply posted First like given First question asked
In the main.c file from an old program I did now write the first build error is undefined reference to 'Em_EEPROM_Start'
Is there some way to find the library associated with this or just what to change it to?
For the second error (related post), I also do not know where to look for finding the duplicate declaration. What header file do I look in?
Both are M0120 errors.
BiBi_1928986
Level 7
Level 7
500 replies posted 250 replies posted 250 sign-ins
Hello.
See this web info:
Usage of Deprecated Components in PSoC Creator Des... - Infineon Developer Community
If you decide to update the component to latest version, you'll need to go through ALL the code to change ALL Em_EEPROM() function calls.  HINT: The older version 1.10 and earlier (from Creator 3.3 and earlier) is far easier to use.
FYI...
Em_EEPROM_Start() has been replaced with Em_EEPROM_Init().  But, it's not a direct substitution.  The new Em_EEPROM() versions carry lots of extra baggage.
So, depending on the reason for updating the old project, you'll need to decide to use the new or keep the old Em_EEPROM component.
To get rid of duplicate declarations, I usually just archive the project, minimal bundle, and then open the archive.  Archiving seems to do some house keeping to get rid of crazy nonsense.  Your mileage may vary.
BiBi_1928986
Level 7
Level 7
Hello.
See this web info:
FYI...
