May 20, 2019
11:51 PM
May 20, 2019
11:51 PM
Hello
I understood previous SLED "About CY8CMBR3108-LQXI device support with Miniprog4"
When I tried to connect EZclick and miniprog to setup MBR3 Device. It can not connect to Miniprog4.
It can not see Miniprog4 port on "Select I2C Target" window.
But It can connect to Miniprog3.
Do you have any advice(Miniprog4 setting .... ) ?
Labels
- ezclick
01:23 AM
May 22, 2019
01:23 AM
Hi user_245806886,
I can see that EZ-Click doesn't populate miniprog4 device. I have requested our software team to look into this issue.
For now, as a workaround , you can use the Bridge control panel to load the .iic file generated using EZ-Click to the eval board.
Let us know if you face any difficulties with that.
Bragadeesh
Bragadeesh
Bragadeesh
