EZI2C write index byte for SCB_EzI2CSetBuffer1 API
YoIs_1298666
250 sign-ins 100 replies posted 100 sign-ins
When writing to EZI2C SCB_EzI2CSetBuffer1 API from Bridge Panel Control, there is an IndexByte after the slave address.
Is it possible to know the value of this IndexByte in the user program(main.c)?
We want to know the first value of locByte or locIndex in EZI2C_EZI2C_INT.c from main.c.
Yocchi
Ekta_N
750 replies posted First like given 250 solutions authored
Hello Yocchi,
You can make use of the EZI2C_EZI2C_GET_OFFSET macro. In the component code the EZI2C_EZI2C_GET_OFFSET is defined as equal to EZI2C_offsetBuf1 which is  Current offset within EZI2C buffer.
In case you want to know the Current index within the EZI2C buffer use the EZI2C_indexBuf1 variable.
The difference of EZI2C_indexBuf1 and EZI2C_offsetBuf1 will give you the number of bytes transferred in a particular transfer.
Best Regards
Ekta
Ekta_N
Hello Yocchi,
Best Regards
Ekta
Hello Ekta-san,
Thank you very much for your good help.
I understood the offset position where I started writing and the pointer position after writing.
[offset position]
#define EZI2C_EZI2C_GET_OFFSET(activeAddress) ((uint32) (EZI2C_offsetBuf1))
[pointer position]
#define EZI2C_EZI2C_GET_INDEX(activeAddress)  ((uint32) (EZI2C_indexBuf1))
Yocchi
