Hi there.
We are planning on implementing something similar to the EVAL_3K3W_BIDI_PSFB control. We are using the CY8C4147AZI-S465 microcontroller.
Can we access the source code of the control schema for this application note and some instructions on implementing it on the CY8C4147AZI-S465 microcontroller?
Best,
Wilson Martinez
Hi!
The source code of EVAL_3K3W_BIDI_PSFB is available upon registering your product/EVK in the following link - https://www.infineon.com/cms/en/product/promopages/productregistration/?intc=PSS.P.B.2021
As you know the evaluation board that you referred to uses XMC controller. You would want to implement the same using PSOC. It is not a straight forward porting as the peripherals and their capabilities are entirely different. It would require an elaborate feasibility study and after that the application should be ported manually.
Please contact your local Sales/FAE if you don't have the evaluation board and would still wish to get the source code.
Pranava
Hi!
Pranava
