Does Infineon maintain a copy of uC/Probe for PSoC on Windows?
If Micrium's uC/Probe is no longer supported for PSoC, is there a preferred method to visualize the performance of the Liquid Level Capacitive Sensors?
I was NOT able to find the code to run the Micrium uC/probe on Windows for the PSoC based Liquid Level Sense example associated with CY8CKIT-02 = CE202479.
Since SiLabs acquired Micrium, they don’t appear to be supporting applications on any MCUs other than their own.
There is one version of Micrium's uC/Probe customized for XMC, that doesn't appear to work with PSoC, on Infineon's site @ https://infineoncommunity.com/uC-Probe-XMC-software-download_ID712?_ga=2.156290555.1967986941.164726...
I found uC/probe target code on github. I did not find code to run uC/probe for PSoC on Windows.
References:
- Code for uc/proble on Github @ https://github.com/weston-embedded/uC-Probe-Target#:~:text=readme.md-,uC%2FProbe%20Target%20Code,jus....
- Documentation for uc/probe on Atlassian @ https://micrium.atlassian.net/wiki/spaces/ucprobedoc/overview
- How can Capsense Tuner be added to CE02479, Liquid Level Sense CY8CKIT-022 code? @ https://community.infineon.com/t5/PSoC-4/How-can-Capsense-Tuner-be-added-to-CE02479-Liquid-Level-Sen...
ispn:39601:1:0
l1:314:1:0
PSoC4MCU
Hi @GrCa_1363456,
You can always use the CapSense Tuner to view the response of the sensors. You may use EZI2C to establish communication between the PSoC device and the tuner.
Nikhil
Hi @GrCa_1363456,
Nikhil
