PSoC™ 4 Forum Discussions
euggersh
Level 4
Level 4
5 sign-ins First solution authored 50 replies posted
I have a BLE service that's used for debug and I don't want it to show up in release builds.  Is there a way of either disabling it for debug builds or for programmatically getting rid of it before I start advertising?
I can't find anything like that in the documentation, but I'm hoping I'm just missing something.
himam_31
Can you have a look at the function CyBle_GattsDisableAttribute().
This function disables the attribute entry for service or characteristic logical group in the GATT database registered
in the BLE Stack.
Hima
himam_31
in the BLE Stack.
Hima
HimaM_31
This works almost perfectly.  I'm calling CyBle_GattsDisableAttribute() with the handle of the secondary service I want to disable.  When I discover services, the characteristics from the secondary service are gone, but the service is still there.  I can work with that, but it would be even better if the service itself was no longer visible.  Is there any way to accomplish that?
himam_31
There is a GATT "Service Changed" indication which can be sent. Can you please try using the same.
Hima
