Hello to all,
I can not measure the temperature of the cip with the DIE_TEMP in PSoC4200 Analog Coprocessor CY8C4A45PVI-481'.
The converter returns the value 440 @ 27 ° C, but "Temp = DieTemp_1_CountsTo_Celsius (adcTemp);" does not return the value in Celsius.
Do you have any dedicated examples?
Thank you
PSoC 4 Architecture
Sample Firmware Source Code PSoC Creator provides numerous example projects that include schematics and example code in the Find Example Project dialog. For component-specific examples, open the dialog from the Component Catalog or an instance of the component in a schematic. For general examples, open the dialog from the Start Page or File menu. As needed, use the Filter Options in the dialog to narrow the list of projects available to select. Refer to the "Find Example Project" topic in the PSoC Creator Help for more information.
http://www.cypress.com/file/139101/download
Try building one of the examples in the PSoC Creator for temperature and let us know how that goes for you.
Hello to all,
I can not measure the temperature of the cip with the DIE_TEMP in PSoC4200 Analog Coprocessor CY8C4A45PVI-481' whit Psoc Creator 4.1
Thank you
