Equip yourself to optimize PSoc4 MCUs for Evs at the EV Webinar. Click here to register.
PSoC™ 4 Forum Discussions
I am using PSoC 4 MCU "CY8C4247AZI-M485", Now when i try to program my MCU with miniprog3's 5 Pin connector, it gives me an error saying this. " Detected SiliconID: "FF FF 13 A1" is not in database ", Please help me in resoving this issue.
Vasanth
Hi Chandresh,
Could you please make sure all the power connections are proper. Please use the following document http://www.cypress.com/file/141176/download  power supply section. Normally this will happen when connection to VCCD pin is not properly given. The voltage to that pins should be between 1.71-1.89V.
VSRS
Vasanth
Hi Chandresh,
VSRS
