jedac_2823961
Hey Guys,
For a project I'm using a CY8C4247AZI-L433 (PSOC4200L serie) MCU. On a certain pin (26) I want to use the PWM component. The documentation for the 4200L says that the Alt. funcion for this pin is tcpwm.line[0]:3. However, in the Design Wide Resources it's giving an Error: Function Net _107.q cannot be reach from this pin.
^ This is the configuration for the PWM pin (26).
Hope to hear from you!
-Jeroen
Vison_Zhang
First comment on KBA 750 replies posted 250 sign-ins
You are using a UDB based PWM component, PORT7 of PSOC4200L don't support connect to internal UDB resource through internal digital routing, change to use a TCPWM component can fix the issue.
Vison_Zhang
Hey VisonZ,
You're right, changing the UDB component to TCPWM worked.
Thanks!
