Rajath_R_Rao
As of now I am using a CY8CKIT-149 devkit, Since I will be using  UART lines as LIN interface for the automotive part, these lines are not available for a Debug, I want to log the debug data in the Controller flash memory, Is this a possibility ? Could we part and use internal flash in this way ?
AlenAn14
500 replies posted 100 solutions authored 250 replies posted
Hi @Rajath_R_Rao ,
Have you tried out the emulated EEPROM code example to read and write data into the flash of PSoC 4 in Modus Toolbox 2.4?
This code example uses the Em_EEPROM Middleware Library 2.10.
You can modify this code example to store your debug data in the emulated EEPROM.
By default, 256 bytes of flash can be used for this purpose. You can increase the same by modifying the macro EM_EEPROM_SIZE.
Hope this helps
Alen
AlenAn14
Hi @Rajath_R_Rao ,
Hope this helps
Alen
Hi Alen,
Sure, I will try this and revert if any queries necessary. Thank you for your time.
Rajath R Rao
