Equip yourself to optimize PSoc4 MCUs for Evs at the EV Webinar. Click here to register.
PSoC™ 4 Forum Discussions
AnMo_4196841
Does anyone have a project with the DHT22 device, or any library for this device?
rola_264706
Level 8
Level 8
Try this program for you DT22 device. This program was designed on a CY8CKIT-049-4xxx you can use another board by Cypress if you need to.
rola_264706
Level 8
Level 8
Here is the data sheet.
Thanks but I had it.
My problem is that I have a project with dht22 device but the data doesn´t show me well, I always get 255 for humidity and temperature
Hi AnMo_4196841
Here is an example project that interfaces DHT11 sensor with a PSoC 62 Wifi BT Kit which can be ported to DHT22. Please let us know if it meets your requirement.
Rakshith M B
Thanks and Regards,
Rakshith M B
Hi, this is my project. Can you see it and tell me what happen?
Antonio
rola_264706
Level 8
Level 8
Hi @rola_264706
Have you tried if this program works well?
This seems interesting but when I try to show it on LCD it doesn't show me the data well.
Antonio
Hi @rola_264706
This is the result that I obtein with the program that you sent.
What can happen?
What LCD are you using what is the part number.  Also the library for you LCD is missing in the program that's why the files are marked with an ?.
@rola_264706 is a LCD 16x2 with the address 0x27.
I have modify the program that you send me, please download the program of the before message and see it.
Rakshith
Hi AnMo_4196841
Please find the attached project for interfacing the DHT22 sensor with PSoC 4.
Rakshith M B
Thanks and Regards,
Rakshith M B
