Hi!
Is there any way to update the firmware as the CySmart does but using a batch file with the appropiate commands ?
PSoC 4 MCU
- ble
- bootloader
- cysmart
Hello @Law1443 ,
We do not offer any CySmart CLI based commands to use in creating a batch script directly. However we do have C# APIs that you could use to create your own Windows console application, output being an executable. You can find the API reference guide here: C:\Program Files (x86)\Cypress\CySmart\1.3\documentation
Let me know if this solution works for you! 🙂
Dheeraj
Can you please elaborate on the Query? like what is the requirement?
1. Are you using CySmart android application or CySmart for windows?
Ganesh
The requirement is that the .batch file updates the firmware of the PSoC as the CySmart would do using the update firmware option.
I'm using CySmart on Windows.
Thanks!
Hello @Law1443 ,
Dheeraj
