hi,
i have a problem with function "CyBle_GapSetLocalName", first i put a name, e.g the name is "+" and i change for "A".
so i use the function "CyBle_GapGetLocalName" and i see if the name really changed(this function returns "A").
However when i go to look for the device on my phone ,the name continues"+".
BLE
Here is a demo project to show the API usage. On programming ,device will advertise with name 'Find Me Target' -> Now connect to a Central Device -> Disconnect -> Again Scan in the Central Device -> You will see a different Device Name.
You can attach your project, so that we can have a look on your implementation.
-Gyan
Did you try to connect your phone with the device. Some phone will not update the device untill you connect with it. This happens because of the BLE driver on the phone side.
Yes, I already tried!
-Gyan
