Could I use two I2C communication at the same time?
KeOn_
Distributor - Macnica (Japan)
100 sign-ins 25 replies posted 10 solutions authored
I want to use two I2C communication at the same time. However, I could only find one port each of SCL and SDA in CY8CKIT042. Is it impossible to process two I2C communication at the same time, or I can realize it if I use the expansion board for CY8CKIT042?
NaMo_1534561
100 replies posted 100 sign-ins 50 replies posted
The PSoC 4200 used in the CY8CKITー042 has two SCBs (Serial Communication Blocks). For I2C communication, (P0_4, P0_5), (P3_0, P3_1), (P4_0, P4_1) can be used for SCL and SDA.
Naoaki Morimoto
NaMo_1534561
Naoaki Morimoto
