mjt_4825471
10 sign-ins 5 questions asked 5 sign-ins
I defined a constant arrary ,but I didn't use it.I can't find this constant arrary in the map file.
Rakshith
250 likes received 1000 replies posted 750 replies posted
Hi @mjt_4825471
Could it be that the array is getting optimized out? Can you try declaring the constant array as 'static volatile' and let us know if that helps?
Thanks and Regards,
Rakshith M B
Rakshith
Hi @mjt_4825471
Thanks and Regards,
Rakshith M B
