I'm connecting a SPI Flash (S25FL116K) to my CYBLE-022001-00 (PRoC BLE module)
I was told there are good examples and app notes on this topic, but my searches don't seem fruitful.
Can anyone share example code or app note(s) on this please.
I tried to download the project from the 100 projects in 100 days, Project051_NOR_Flash_Bootloader External Memory Bootloader using NOR Flash. However, when I downloaded the .zip file, it appeared empty and I was not able to extract any files. I know that's a different problem, but thought I would mention it.
Any thoughts?
Thanks!
There are sample projects available for the SPI master component - just right click on it. Tro read the device ID as a first try to get it goind. After that, its just a matter of sending the correct commands.
If the ZIP cannot be extracted, either you are not using the correct extractor program (maybe try 7-zip), or its corrupt (can you share a link?).
I checked the link again now, now the file downloads and can open it.
is the link...
thank you for your response! I will take a look at your suggestions and let you know how it goes.
