i am getting the following error and i don't know were to resolve It.  Attached pis of the error i am getting
AnkitaS_51
It shows that some net is not connected or not  having source/sink
Are you able to build successfully in Creator, then you can neglect this error.
AnkitaS_51
No is does nott buid successfully ... it  stops the build.  Does there error mean i do not have a pin defined correctly?
i will attach my work space bundle so you can see error
Ok i found i had a floating net ... interesting it was a off chip net (blue) and still gave this error. Anyway i removed it and it resolved the issue.
Scott
