PSoC™ 4
DeAa_335316
Level 4
First like received
Level 4
I need Code optimization and Dynamic memory allocation related  document and videos. which i can apply in my project.
What the factor i have to consider while optimization?
How to allocate DMA in my project?
what are the testing method i can select  for my project and HOW ?
# i am using Designer 3.0 SP1 + MiniProg3 -->Target Device --> CYBLE 02200001
*Please Help me
Bob_Marlowe
Level 10
50 questions asked 10 questions asked 1000 solutions authored
Level 10
You took something wrong: Designer is for PSoC1 chips only and your target device is probably a CYBLE-022001-00 (correct me, if I am wrong).
You will need PSoC Creator latest version which is now 3.3.
There is no fixed percentage that optimization will save, I would suggest you to try it, using "speed" or "size" optimization compared to "none" or "Debug".
The PRoC CYBLE-022001-00 module has not got any DMA, so you'll need to use "poor man's DMA" 😉 which means memcpy() or something similar.
Bob
Bob_Marlowe
Level 10
Level 10
Bob
