PSoC™ 4 Forum Discussions
KaKo_4074056
Level 4
Level 4
25 replies posted 50 sign-ins 25 sign-ins
Do you have a code example using CTB peripheral driver below for PSoC4 (4100S Max)? It does not exist in the template application of MTB.
https://infineon.github.io/mtb-pdl-cat2/pdl_api_reference_manual/html/group__group__ctb.html
I found an example of CTB for other device from GitHub.
https://github.com/Infineon/mtb-example-pmg1-ctbm-opamp-comparator
Best regard,
LeoMathews
100 sign-ins 25 solutions authored 100 replies posted
Hi @KaKo_4074056
Please refer to the code example SAR ADC BASIC under peripherals which use CTB peripheral for PSoC4 (4100S Max).
Thanks and Regards,
Leo
LeoMathews
Hi @KaKo_4074056
Thanks and Regards,
Leo
Hi Leo,
Thanks for your quick reply. I'll check that.
LeoMathews
Hi @KaKo_4074056 ,
Thread was locked due to inactivity for long time, you can continue the discussion on the topic by opening a new thread with reference to the locked one. The continuous discussion in an inactive thread may mostly be unattended by community users.
Thanks and Regards,
Leo
