Hello Everyone,
I am using my Cypress BLE as a broadcaster. Is there any API to change the advertisement intervals in my code?
Thank you
Hi Dharav,
You need to update the advertisement intervals only when the device is not broadcasting/advertising. So let's assume you have stopped broadcasting either by using CyBle_ExitDiscoveryMode() or CyBle_GappStopAdvertisement(). Include the below lines for restarting the broadcast with different adv intervals:
                cyBle_discoveryModeInfo.advTo = (Adv Timeout);
                cyBle_discoveryModeInfo.advParam->advIntvMin = (Min Adv Interval/0.625);
                cyBle_discoveryModeInfo.advParam->advIntvMax = (Max Adv Interval/0.625);
                CyBle_GappStartAdvertisement(CYBLE_ADVERTISING_CUSTOM); //you can also use EnterDiscoveryMode() instead
Hi Dharav,
