FrPo_1282226
Level 4
Level 4
25 replies posted 10 replies posted 10 questions asked
Hello there,
Do you know if is possible to change the sysclock frequency for a PSOC 4 dynamically?
I need to run most of the time the PSoC @ 1.5 MHz, but occasionally I need to run at 48 MHz.
CySysClkWriteSysclkDiv(); should do the job... but it doesn't seems to work.
Do you have any suggestions?
Thank you!
Ekta
750 replies posted First like given 250 solutions authored
Yes, it is possible to change the sysclock frequency for PSoC 4 dynamically.
MikeAustin
Level 4
Level 4
25 replies posted 25 sign-ins 10 replies posted
Have a look at the response to this post I put up last year - it makes mention of changing the IMO frequency dynamically.  I never ended up trying it, as I was able to solve my issue using a different approach
https://community.cypress.com/t5/PSoC-4-MCU/Changing-IMO-and-ADC-Sampling-frequencies-in-code/m-p/11...
Cheers,
Mike
Ekta
Thank you!
