We can find the centroid position equation for CapSense Slider in "AN64846 - Getting Started with CapSense ".
Which of the CapSense Configuration and Tuner measurements does each variable refer to?
The following are the values actually measured by Tuner and values of CapSense configuration.
Maybe "Resolution" means "Maximum position 232".
The n means 6.
What is "maximum" and Si?
Yocchi
PSoC 4 MCU
Hi @YoIs_1298666,
Resolution indicates the maximum count number to be reported, and this corresponds to the maximum position value.
n corresponds to the number of segments present in the slider
maximum corresponds to the index number of the segment whose signal reported is the highest.
Si corresponds to the difference counts of the i^th segment of the slider. Difference counts is defined as
difference counts = raw counts- baseline
Nikhil
Hi @YoIs_1298666,
Nikhil
Hello Nikhil-san,
Thank you very much for your reply.
What is index number of the segment whose signal reported is the highest of "maximum"?
SLD_sns2 is the highest result of the attached tuner. What is this index number?
Yocchi
