I am using the Capsense Tuner through Bluetooth with PSoC 4 and I have noticed that the refresh rate varies. Why is it that it is not constant? Is there a way to set this parameter such as that is not changing?
Thank you in advance.
PSoC 4 MCU
Hi @vebr_4751981 , The refresh rate will vary depending on the following:
1. Loop time of the capsense scans. This also determines how often CyBle_ProcessEvents() is called.
2. BLE traffic /throughput.
Also, are you referring to the refresh rates you see in Tuner?
Bragadeesh
Bragadeesh
