Hi
I try assgin different value to " CapSense_dsRam.wdgtList.number1.fingerTh" to adjust button sensitivity.
When I tested it no difference.
If I need dynamically adjust capsense button sensitivity.
How can I do ?
PSoC 4 MCU
- capsense
Hi @AdamCheng,
No, dsRam contents will not be lost when the device is in sleep mode.
The contents are lost when the device enters hibernate or stop modes.
Nikhil
Hi @AdamCheng,
Changing the dsRam contents should serve the change.
Can you send the tuner waveforms and values of all CapSense parameters?
Nikhil
Dear Nikhil,
I attach one button of seeting, Because I only try to modify this dsRam parameter.
The current design is no problem, but it I want to add the adjustment method to change the sensitivity after production assembly.
In the test program, I added like red circled on the below.
When press num 4~9 can change num1 button finger threshold value.
Adam
Hi @AdamCheng,
The current design is no problem >>> Okay.
The procedure followed by you is correct. The finger threshold does get changed when you use
CapSense_dsRam.wdgtList.number1.fingerTh = <number>;
I am attaching my project here (done on the 4200M Pioneer kit).
In my project, I have the total scan time approximately equal to 5ms. In the code, the conditions are given such that for every 5 seconds, the finger threshold gets updated between 90 and 70 (I am starting the application with an initial finger threshold of 100).
You may verify the same by going to debug mode and observing the dsRam contents.
Figure 1: Initially, the finger threshold is equal to 100 (0x64)
Figure 2: After approximately 5 seconds, the finger threshold is changed to 90 (0x5A)
Figure 3: Again, after approximately 5 seconds, the finger threshold is changed to 70 (0x46)
Nikhil
Dear Nikhil,
Thanks for your reply
I check dsRam in debug mode. I know what the problem is.
Because our design goes into sleep mode.
I found that dsRam will return to the default value after entering sleep mode.
Hi @AdamCheng,
Nikhil
Dear Nikhil,
I found out that our system resets Psoc4.
Thank you for your reminder.
