My custom board usesCY8C4248LQI-BL553 and I got troubled some hardfault issue. So I start capsense tuner to find out what is going on and got SNR value(signal noise ratio). The result is 38.37 and I think it is pretty low value compare with my CY8CKIT-042 development kit(which is 180).
The question is : Is it really low value for capsense? Is there limited guideline for capsense SNR? If it so, is there any way to reduce SNR?
Best regards, BK.
Hi
Q: Is it really low value for capsense? Is there limited guideline for capsense SNR? If it so, is there any way to reduce SNR?
A: I think it is not low value for capsense. We should ensure the SNR value is Greater or Equal to 5:1.
More about the proximity capsense tuning, please refer to the linker:
What do you mean about the hardfault issue? I think it has no relationship with the Capsense NSR.
Hi
hi, @LinglingG_46 , thanks for the answer. So my project has LCD screen that controled by 6 different capsense button. But sometimes(in a weeks or days), capsense touch is dead, and that make me can't control LCD screen. So I hypothesized that Capsense was the cause. But I am not sure about that.
We should get the capsense parameters when it enters dead state, for example :rawcount,baseline,diffcount. If we have the debug interface, we can choose running to target to get the code position.
