Equip yourself to optimize PSoc4 MCUs for Evs at the EV Webinar. Click here to register.
PSoC™ 4 Forum Discussions
I have a load cell based on Capacitance variation. The initial value of this sensor is about 100 pF and by applying load the capacitance variation is about 1pF/kg.
I need to measure this capacitance variation using PSOC-4 or PSOC5 kits.
May you please explain how I can make it. Had a look on many of examples and datasheets, none of them is related to my situation.
I have found some functions such as CapSense_ReadSensorRaw() (which returns 0), but have no idea what it does exactly and what other functions should be called before to set it up.
RyanZhao
750 replies posted 100 sign-ins 100 likes received
Hi Amir,
The BIST functions of CapSense may help to measure external capacitance.
For more details, read datasheet of CapSense Component.
If you are a beginner of PSoC CapSense, recommend to learn it with start from:
http://www.cypress.com/documentation/application-notes/an64846-getting-started-capsense
http://www.cypress.com/file/46081/download
Ryan
