Equip yourself to optimize PSoc4 MCUs for Evs at the EV Webinar. Click here to register.
PSoC™ 4 Forum Discussions
AnRa_1522781
Hi All,
I am using a PSoC 4100S device with CapSense.
There seems to be two CapSense components CapSense[v6.0] and CapSense_ADC[v6.0].
What is the difference between these two components?
BragadeeshV
Hi AnRa_1522781​,
CapSense_ADC[v6.0] component is used when you want single slope ADC and CapSense in your design. This component time multiplexes CapSense and ADC operation. This is specifically useful when you want both CapSense and ADC in your design but your device doesn't have a separate ADC block such as in 4000 S device.
In your case, you are using 4100 S device which has a separate SAR ADC block. So it is better if you use CapSense [v6.0].
Please refer to the component datasheet for more information.
Bragadeesh
Bragadeesh
BragadeeshV
Hi AnRa_1522781​,
Bragadeesh
Bragadeesh
