My project is very simple. Is one button is pressed, related led on. If the button pressed again, led off. however I could not prevent the false touch. I do not want to led on or off when I falsely touch a button.
I have an idea which is following;
if a sensor active, related sensor flag would set. if time between the flags is more than 500 ms, do your job. If lesser than 500 ms, do not do any thing.
How I can put my code to this idea? could you please give an example code because you have my project.
PSoC 4 MCU
Hi @Marcus_Hellen,
You can use the enable sensor auto reset feature to avoid false touches.
https://community.infineon.com/t5/PSoC-4/What-is-the-quot-baseline-quot/td-p/326788 - refer to this thread for information about enable sensor auto reset. Also, refer to CapSense design guide - https://www.cypress.com/file/46081/download for more details.
Nikhl
Hi @Marcus_Hellen,
Nikhl
