I have a Liquid tolerance problem with CapSense. When two CapSense buttons are covered by a water stain.
If I touch either button, both buttons will be activated . How do I get these two buttons to activate correctly(the two buttons do not activate at the same time). Achieve the purpose of Liquid tolerance?
PSoC 4 MCU
- liquid tolerance
Hi @song,
Using shield hatch around the sensors is the right way.
Can you set the inactive sensors' connection to shield and check if you observe the same?
Nikhil
Did you implement a Shield Electrode?
Yes, I implement a Shield Electrode instead of ground。
Hi @song,
Nikhil
