Below is my firmware, and it has watchdog and ADC interrupt. I have to add enter and exit critical section function so that the cap touch process will not be interrupted. Please tell me where can I insert at below code the enter and exit critical section function
while(1u)
ADCHandler();
CySysWdtResetCounters(CY_SYS_WDT_COUNTER1_RESET);
if(BatteryOutOfRange==0)
/* Do this only when a scan is done */
if(CapSense_NOT_BUSY == CapSense_IsBusy())
CapSense_ProcessAllWidgets(); /* Process all widgets */
#ifdef USER_CAP_SENSE_TUNE_ENABLE
CapSense_RunTuner(); /* To sync with Tuner application */
#endif // cap sense tune enable
CapSense_CheckState();
CapSense_ScanAllWidgets(); /* Start next scan */
/* Display CapSense state using LEDs */
else CapTouchOutput_Write(0u);
void CapSense_CheckState(void)
static uint16_t guardReleaseCount = 0, SensorTouchCount = 0,guardState = 1, sensorState=0;
static uint8_t press_print = 0;
if (CapSense_IsWidgetActive(CapSense_GUARD_WDGT_ID))
guardState=1;
guardReleaseCount = 0;
else
if(++guardReleaseCount >= GUARD_RELEASE_COUNT_TH)
guardState=0;
if (CapSense_IsWidgetActive(CapSense_BUTTON0_WDGT_ID))
if(++SensorTouchCount>=SENSOR_TOUCH_COUNT_TH)
sensorState=1;
SensorTouchCount=0;
else
sensorState=0;
SensorTouchCount = 0;
if(guardState ==0 && sensorState==1)
if(press_print==0)
User_UART_UartPutString("Button Pressed\r\n");
press_print = 1;
CapTouchOutput_Write(1u);
else
press_print = 0;
void ADCHandler(void)
uint8 channel = CHANNEL_1;
int16 adcVal;
int32 mVolts;
int32 BatteryVolt;
static uint8 FirstBoot=1;
Vbat_EN_Write(1u);
if(ADCdataReady != 0u)
adcVal = ADC_GetResult16(CHANNEL_1);
/* Check for ADC window limit interrupt */
if(ADCwindowFlag != 0u)
BatteryOutOfRange = 1;
else
/* Convert the ADC counts of active channel to mVolts */
mVolts = (int32)ADC_CountsTo_mVolts(channel, adcVal);
BatteryVolt = mVolts * BATTERY_VOLTAGE_GAIN + BATTERY_OFFSET;
if(FirstBoot)
if(BatteryVolt>=BATTERY_VOLTAGE_LOWER_LIMIT && BatteryVolt <=BATTERY_VOLTAGE_UPPER_LIMIT)
BatteryOutOfRange = 0;
if(BatteryOutOfRange)
if(BatteryVolt>=BATTERY_VOLTAGE_LOWER_HYSTERESIS && BatteryVolt <=BATTERY_VOLTAGE_HIGHER_HYSTERESIS)
else
if(BatteryVolt>=BATTERY_VOLTAGE_UPPER_LIMIT || BatteryVolt<=BATTERY_VOLTAGE_LOWER_LIMIT)
FirstBoot = 0;
ADCdataReady = 0u;
please refer to the below codes:
You can't disable the interrupt while scanning, because we should use the CSD ISR to report that scanning is done.
We only need to disable the interrupts while checking the capsense scan status.
If you want to avoid that the CSD scan is disturbed by other interrupts, you only to set the CSD ISR as the highest priority in your system.
uint8 interruptState;
/* Disable interrupts, so that ISR is not serviced while
* checking for CapSense scan status.
interruptState = CyEnterCriticalSection();
/* Enable interrupts for servicing ISR */
CyExitCriticalSection(interruptState);
