Cap Sense
rava_4805041
Schematic Verification For Cap Sense Touch Switch using  CY8C4124AZI-S433 MCU
ncbs
500 replies posted 50 likes received 250 sign-ins
Hi @rava_4805041,
> P0.4 and P0.5 - if they are used for I2C, have a series resistor of 330ohm along with the pull-up resistor of 4.7kohm. If they are used for SPI, then the schematic is fine.
> pin 39 and pin 40: only 1 pair of decoupling capacitors [1uF and 0.1uF] is enough. Remove the extra capacitors present.
> Button 9_ Led2 on pin 17: what does this pin signify?
Nikhil
ncbs
Hi @rava_4805041,
Nikhil
ncbs
Hi @rava_4805041,
To be more specific on the de-coupling capacitors point, use [1uF+0.1uF] pair on pin 39 and another  [1uF+0.1uF] pair on pin 40.
Nikhil
rava_4805041
    Please find the updated schematic and BOM as per given requirement for Review.
ncbs
Hi @rava_4805041,
I see the de-coupling capacitor point beng addressed to - Yes, the new schematic have them correctly connected.
Nikhil
Thanks for quick update.
Rahul
