Hello-
I have an existing project where the Peripheral is not setting the manufacturing data to companyid 305 which is Cypress according to Bluetooth Specifications:
https://www.bluetooth.com/specifications/assigned-numbers/company-identifiers
I am using a Central BLE app that is running the Cypress 100 Projects in 100 days (Day 20) UART to BLE Central project:
My question is it possible to connect to the peripheral without having this manufacturing data? I see code that is looking for this but I am not sure whether it is required or not.
File: app_Ble.c
case CYBLE_EVT_GAPC_SCAN_PROGRESS_RESULT:
advReport = (CYBLE_GAPC_ADV_REPORT_T *) eventParam;
/* check if report has manfacturing data corresponding to the intended matching peer */
if((advReport->eventType == CYBLE_GAPC_SCAN_RSP) && (advReport->dataLen == 0x06) \
&& (advReport->data[1] == 0xff) && (advReport->data[2] == 0x31) \
&& (advReport->data[3] == 0x01) && (advReport->data[4] == 0x3b) \
&& (advReport->data[5] == 0x04))
peerDeviceFound = true;
memcpy(peerAddr.bdAddr, advReport->peerBdAddr, sizeof(peerAddr.bdAddr));
peerAddr.type = advReport->peerAddrType;
#ifdef PRINT_MESSAGE_LOG
UART_UartPutString("\n\r\n\rServer with matching custom service discovered...");
#endif
break;
Rohan
BLE
Rohan,
The CyBle_GapcConnectDevice() sends a connection request to peripheral device. Now, if you see in the code , you are calling this API by checking the flag "peerDeviceFound" as below and this flag you are setting only after comparing the manufacture data.
if(peerDeviceFound)
cyble_api_result = CyBle_GapcConnectDevice(&peerAddr);
if(CYBLE_ERROR_OK == cyble_api_result)
peerDeviceFound = false;
So , this default project will not connect to any peripheral device if that device does not have the same manufacture data set in scan response packet.
-Gyan
