Mitchell_shen
Level 4
Level 4
100 sign-ins 5 solutions authored First solution authored
I can't find Automotive grade PSoC4 parts number on Cypress website.
For example CY8C4245AZA-M445,
The datasheet will indicate to https://www.cypress.com/file/377971/download
There are no include any automotive grade parts information.
How to get correct datasheet?
Ashish
25 likes received 50 solutions authored 100 replies posted
Hi ,
Use following link:
https://www.cypress.com/documentation/datasheets/automotive-psoc-4-psoc-4200m-family-datasheet-progr...
The datasheet which you had referred is not for Automotive grade PSoC.
Ashish
Ashish
Hi ,
Use following link:
Ashish
Dear Ashish,
Thanks your correct link provided.
But without CDC support, how to search(key word) on Cypress website?
I am try to use automotive parts number search again.
The datasheet in the product information page still incorrect.
https://www.cypress.com/part/cy8c4245aza-m443
Mitchell
Hi Mitchell,
You may try "automotive psoc 4200m", the datasheet is listed as the 2nd result for me, see below screenshot.
I agree searching with part number may be common for most users, and the datasheet in the product information page should link to the right document. We will ask web masters to fix this issue.
Roy
Roy Liu
Roy_Liu
First comment on blog 1000 replies posted 500 solutions authored
The incorrect linking issue is fixed, if you click the pdf datasheet icon on the product webpage - https://www.cypress.com/part/cy8c4245aza-m443  you will see the correct datasheet now.
Roy Liu
