Equip yourself to optimize PSoc4 MCUs for Evs at the EV Webinar. Click here to register.
PSoC™ 4 Forum Discussions
Hi Guys,
i started working with the Psoc 4 Development Kit a few day ago and everything works fine. Windows suddenly reinstalled the drivers while i worked with the Kit. But not successful. The Psoc Creator can`t find the Kit now... I tried to reinstall the drivers but without success.
If i connect the Kit with USB the green status LED is fading slow.
Some ideas what i have to do to solve my Problem?
Dirk
Bob_Marlowe
Level 10
Level 10
Press the reset button for > 5s
Bob
Bob_Marlowe
Level 10
Level 10
Welcome in the forum, Dirk!
A fading LED might be a power problem (shortcut??). Can you verify that your BLE module is perfectly seated in the connectors.
The green LED shows the status of the Kitprog on your BLE Pioneer kit.
Do you have a chance to measure the voltage on the board using a multimeter?
Bob
PS: Where in Germany are you located? I live near Bremen.
Hi Bob,
input voltage 4,8V and the 3,3V are stable too. The Power LED doesen`t fade. Only the green status LED. It looks like a defined system state but i can`t find one with a fading LED. If I push the reset button while powering up the system i can start the Bootloader state.
The kit is detected as a mass storage from Windows...  Are there known cases with corrupted file systems? Windows or Kit?
Im located in Stuttgart but born and grown up in Lübeck/Bad Schwartau.
Dirk
Bob_Marlowe
Level 10
Level 10
Bob
I could swear i tryed this. 😉 THX!!!
