Hi, I am very new to PSOC programming. I basically need to get voltage readings from an electric (voltage divider) circuit and transfer it to a PC over Bluetooth. Is it possible to do this using PSoC 4 BLE pioneer kit, or any other PSoC device? If so, then can someone please give me some guidelines on how I should proceed?
Thanks!
Bob_Marlowe
Level 10
Level 10
In blue color are all external parts and connections. You find those in Creator Component Catalog under "Off Chip"-tab.The SW2 in your case is to be found on the CY8CKIT-042 BLE Pioneer kit. Have a look into the schematics.
Bob
rola_264706
Level 8
Level 8
Rawnak: Here is a program that sends data with a temperature to the dongle using the ADC component.  You can modify it as you need too.
Thanks ! I have a question regarding this project. Which components has been used for the button? I have attached a snapshot of the part of the top design schematic I am referring to.
Kind Regards
Bob_Marlowe
Level 10
Level 10
Bob
Thanks. It was the "Dedicated Interrupt" in the "Input" tab that I hadn't enabled and hence was not being able to connect the interrupt to the switch.
