PSoC™ 4 Forum Discussions
haal_4512006
I have a 2 phase sensor less BLDC motor which i intend to control. I was surfing through the web, saw this cool kit used to control BLDC motors.  The motor which comes along with the kit is a conventional 3 phase BLDC motor but i want to control a 2 phase BLDC instead. Can this kit be used in my intended application?
Vasanth
Hi Hammad,
From my observation the driving circuit for 2 phase circuit seems to be different from the 3 phase circuit. In the 037 kit H bridges are made use. But for 2 phase circuit it is not necessary. An NMOS seems to be sufficient in its case. You may be able to use all the 4 NMOS and leave all the PMOS untouched( in the available H bridge), just for reusing the hardware for your purpose. Then again see the connections required. J19, J20, J21 select the bridge connections as required. Additionally please see the kit user guide to understand the driver circuit.
Vasanth
Vasanth
Hi Hammad,
Vasanth
